Audio Output Host example
Description
This example implements an audio interface class host mode device that enumerates an audio interface class device (USB speakers) and sends samples to the device. The samples are created by a simple square wave generator in a timer ISR and shipped out the streaming isochronous output pipe when a button is pressed on the board.
Getting started
This example can be built and debugged using two compiler tool chains. Visit http://www.lpcware.com/content/project/nxpusblib/build-it to learn how to setup and configure these tool chains to build this example.
Compiler build configurations
The software that makes up this example is designed to run on many different development boards. Therefore the compiler must be configured to build an image that is targeted to the development board you are using. This section explains how to set these build configurations for each of the supported compilers.
LPCXpresso IDE
Configure projects
  right click on the BSP project in the project explorer window
  click Build Configurations->Set Active->(see configuration in table below)
  repeat these steps with the CDL, nxpUSBlib, and Example_AudioOutputHost
Configure MCU
  right click on the Example_AudioOutputHost project in the project explorer window
  click Properties->C/C++ Build->MCU settings->(see configuration in table below)
Configure the indexer
  click Window->Preferences->C/C++->Indexer->Use active build configuration
BSP
CDL
nxpUSBlib
MCU
LPC1850  / Hitex
LPC18xx_HITEX
LPC18xx
LPC18xx_Host
LPC18xx
LPC1850
Keil uVision 4 IDE
Configure a Batch Build
  click on Project->Batch Build...
  expand the BSP project to display a list of project targets
  select the project target by checking the appropriate checkbox
    (see target list in table below)
  repeat these steps with the CDL, nxpUSBlib_Device, and Example_AudioOutputHost
BSP
CDL
nxpUSBlib_Host
LPC1850  / Hitex
HITEX1800
LPC18xx
LPC18xx_Host
HITEX1800
Board connections and configurations
LPC18xx_HITEX (LPC1850 Hitex Evaluation Board)  older A2 design
schematic ./BSP/schematics/HITEX_SCM_LPC1850EVA-A2-2.pdf
Connect the JTAG to the 20 pin receptacle marked X4 JTAG
Plug USB speakers into the type A receptacle marked X10
Connect a 9-pin serial cable into the receptacle marked UART X1. Connect the other end of this cable into a PC running a terminal program.
To power the board:
  Connect the type-B end of a powered USB cable into the receptacle marked X13
  or
  Supply 5v to the DC connector labeled X14
LPC18xx_HITEX (LPC1850 Hitex Evaluation Board)  newer A3 design
schematic ./BSP/schematics/HITEX_Final_LPC1850EVA-A3.pdf
PC configuration
Use a PC running Windows XP, Vista or 7 to display runtime diagnostics that can be viewed with a terminal emulation program like Teraterm or Hyperterm. The baud rate in these programs should be set to 9600.
Build and debug the example
LPCXpresso IDE
In the project explorer window of the IDE right click on the Example_AudioOutputHost project and select Debug As->C/C++ MCU Application
In the main window of the IDE click Run->Resume to start running the application
Keil uVision 4 IDE
In the Batch Build window, select the project targets as described in Compiler Build Configurations and then click Build
In the main window of the IDE click Debug->Start/Stop Debug Session click Debug->Run
How this example runs and what to look for
When the example is first run the terminal window will display:
Audio Output Host Demo running.
When the USB speakers are plugged in the terminal window will display:
Audio Device Enumerated.
When the button is pressed on the board the USB speakers will produce a loud tone. When the button is not pressed the USB speakers will be silent.
When the USB speakers are unplugged the terminal window will display:
Device Unattached.
%3CLINGO-SUB%20id%3D%22lingo-sub-1118113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%9F%B3%E9%A2%91%E8%BE%93%E5%87%BA%E4%B8%BB%E6%9C%BA%E7%A4%BA%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1118113%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId-381647819%22%20id%3D%22toc-hId-1303176795%22%3E%3CSTRONG%3E%3CBIG%3E%E6%8F%8F%E8%BF%B0%3C%2FBIG%3E%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%E6%AD%A4%E7%A4%BA%E4%BE%8B%E5%AE%9E%E7%8E%B0%E4%BA%86%E9%9F%B3%E9%A2%91%E6%8E%A5%E5%8F%A3%E7%B1%BB%E4%B8%BB%E6%9C%BA%E6%A8%A1%E5%BC%8F%E8%AE%BE%E5%A4%87%EF%BC%8C%E8%AF%A5%E8%AE%BE%E5%A4%87%E6%9E%9A%E4%B8%BE%E9%9F%B3%E9%A2%91%E6%8E%A5%E5%8F%A3%E7%B1%BB%E8%AE%BE%E5%A4%87%EF%BC%88USB%20%E6%89%AC%E5%A3%B0%E5%99%A8%EF%BC%89%E5%B9%B6%E5%B0%86%E6%A0%B7%E6%9C%AC%E5%8F%91%E9%80%81%E5%88%B0%E8%AF%A5%E8%AE%BE%E5%A4%87%E3%80%82%E6%A0%B7%E6%9C%AC%E7%94%B1%E5%AE%9A%E6%97%B6%E5%99%A8%20ISR%20%E4%B8%AD%E7%9A%84%E7%AE%80%E5%8D%95%E6%96%B9%E6%B3%A2%E5%8F%91%E7%94%9F%E5%99%A8%E5%88%9B%E5%BB%BA%EF%BC%8C%E5%B9%B6%E5%9C%A8%E6%9D%BF%E4%B8%8A%E6%8C%89%E4%B8%8B%E6%8C%89%E9%92%AE%E6%97%B6%E9%80%9A%E8%BF%87%E6%B5%81%E5%BC%8F%E7%AD%89%E6%97%B6%E8%BE%93%E5%87%BA%E7%AE%A1%E9%81%93%E5%8F%91%E9%80%81%E5%87%BA%E5%8E%BB%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId--1425806644%22%20id%3D%22toc-hId--504277668%22%3E%3CBIG%3E%3CSTRONG%3E%E5%BF%AB%E9%80%9F%E5%85%A5%E9%97%A8%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%E4%B8%A4%E4%B8%AA%E7%BC%96%E8%AF%91%E5%99%A8%E5%B7%A5%E5%85%B7%E9%93%BE%E6%9D%A5%E6%9E%84%E5%BB%BA%E5%92%8C%E8%B0%83%E8%AF%95%E6%AD%A4%E7%A4%BA%E4%BE%8B%E3%80%82%E8%AE%BF%E9%97%AE%3CA%20_jive_internal%3D%22true%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fexternal-link.jspa%3Furl%3Dhttp%253A%252F%252Fwww.lpcware.com%252Fcontent%252Fproject%252Fnxpusblib%252Fbuild-it%22%20target%3D%22_blank%22%3Ehttp%3A%2F%2Fwww.lpcware.com%2Fcontent%2Fproject%2Fnxpusblib%2Fbuild-it%3C%2FA%3E%E4%BA%86%E8%A7%A3%E5%A6%82%E4%BD%95%E8%AE%BE%E7%BD%AE%E5%92%8C%E9%85%8D%E7%BD%AE%E8%BF%99%E4%BA%9B%E5%B7%A5%E5%85%B7%E9%93%BE%E6%9D%A5%E6%9E%84%E5%BB%BA%E6%AD%A4%E7%A4%BA%E4%BE%8B%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId-1061706189%22%20id%3D%22toc-hId-1983235165%22%3E%3CBIG%3E%3CSTRONG%3E%E7%BC%96%E8%AF%91%E5%99%A8%E6%9E%84%E5%BB%BA%E9%85%8D%E7%BD%AE%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%E6%9E%84%E6%88%90%E6%AD%A4%E7%A4%BA%E4%BE%8B%E7%9A%84%E8%BD%AF%E4%BB%B6%E8%AE%BE%E8%AE%A1%E7%94%A8%E4%BA%8E%E5%9C%A8%E8%AE%B8%E5%A4%9A%E4%B8%8D%E5%90%8C%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E8%BF%90%E8%A1%8C%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%BF%85%E9%A1%BB%E9%85%8D%E7%BD%AE%E7%BC%96%E8%AF%91%E5%99%A8%E6%9D%A5%E6%9E%84%E5%BB%BA%E9%92%88%E5%AF%B9%E6%82%A8%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E5%BC%80%E5%8F%91%E6%9D%BF%E7%9A%84%E5%9B%BE%E5%83%8F%E3%80%82%E6%9C%AC%E8%8A%82%E4%BB%8B%E7%BB%8D%E5%A6%82%E4%BD%95%E4%B8%BA%E6%AF%8F%E4%B8%AA%E6%94%AF%E6%8C%81%E7%9A%84%E7%BC%96%E8%AF%91%E5%99%A8%E8%AE%BE%E7%BD%AE%E8%BF%99%E4%BA%9B%E6%9E%84%E5%BB%BA%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-1752267663%22%20id%3D%22toc-hId--1621170657%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3ELPCXpresso%20IDE%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSTRONG%3E%E9%85%8D%E7%BD%AE%E9%A1%B9%E7%9B%AE%3C%2FSTRONG%3E%3C%2FP%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%E5%9C%A8%E9%A1%B9%E7%9B%AE%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E7%AA%97%E5%8F%A3%E4%B8%AD%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%20BSP%20%E9%A1%B9%E7%9B%AE%3CBR%20%2F%3E%E7%82%B9%E5%87%BBBuild%20Configurations-%26gt%3BSet%20Active-%26gt%3B%EF%BC%88%E8%A7%81%E4%B8%8B%E8%A1%A8%E4%B8%AD%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%89%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%20CDL%E3%80%81nxpUSBlib%20%E5%92%8C%20Example_AudioOutputHost%20%E9%87%8D%E5%A4%8D%E8%BF%99%E4%BA%9B%E6%AD%A5%E9%AA%A4%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3E%E9%85%8D%E7%BD%AE%20MCU%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%9C%A8%E9%A1%B9%E7%9B%AE%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E7%AA%97%E5%8F%A3%E4%B8%AD%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%20Example_AudioOutputHost%20%E9%A1%B9%E7%9B%AE%3CBR%20%2F%3E%E7%82%B9%E5%87%BB%E5%B1%9E%E6%80%A7-%26gt%3BC%2FC%2B%2B%20Build-%26gt%3BMCU%E8%AE%BE%E7%BD%AE-%26gt%3B%EF%BC%88%E8%A7%81%E4%B8%8B%E8%A1%A8%E9%85%8D%E7%BD%AE%EF%BC%89%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSTRONG%3E%E9%85%8D%E7%BD%AE%E7%B4%A2%E5%BC%95%E5%99%A8%3C%2FSTRONG%3E%3CBR%20%2F%3E%E5%8D%95%E5%87%BB%E7%AA%97%E5%8F%A3-%26gt%3B%E9%A6%96%E9%80%89%E9%A1%B9-%26gt%3BC%2FC%2B%2B-%26gt%3B%E7%B4%A2%E5%BC%95%E5%99%A8-%26gt%3B%E4%BD%BF%E7%94%A8%E6%B4%BB%E5%8A%A8%E6%9E%84%E5%BB%BA%E9%85%8D%E7%BD%AE%3C%2FP%3E%3CDIV%20class%3D%22j-rte-table%22%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%222%22%20cellspacing%3D%228%22%20style%3D%22border-width%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CTBODY%20style%3D%22border-top-color%3A%20%23cccccc%3B%22%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20align%3D%22center%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20background-color%3A%20%23ffcc99%3B%20font-size%3A%2012px%3B%22%20valign%3D%22middle%22%3E%3C%2FTD%3E%3CTD%20align%3D%22center%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20background-color%3A%20%23ffcc99%3B%20font-size%3A%2012px%3B%22%20valign%3D%22middle%22%3E%3CP%3EBSP%3C%2FP%3E%3C%2FTD%3E%3CTD%20align%3D%22center%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20background-color%3A%20%23ffcc99%3B%20font-size%3A%2012px%3B%22%20valign%3D%22middle%22%3E%3CP%3ECDL%3C%2FP%3E%3C%2FTD%3E%3CTD%20align%3D%22center%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20background-color%3A%20%23ffcc99%3B%20font-size%3A%2012px%3B%22%20valign%3D%22middle%22%3E%3CP%3EnxpUSBlib%3C%2FP%3E%3C%2FTD%3E%3CTD%20align%3D%22center%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20background-color%3A%20%23ffcc99%3B%20font-size%3A%2012px%3B%22%20valign%3D%22middle%22%3E%3CP%3E%E7%A4%BA%E4%BE%8B_AudioOutputHost%3C%2FP%3E%3C%2FTD%3E%3CTD%20align%3D%22center%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20background-color%3A%20%23ffcc99%3B%20font-size%3A%2012px%3B%22%20valign%3D%22middle%22%3E%3CP%3EMCU%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20align%3D%22center%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20background-color%3A%20%23ffcc99%3B%20font-size%3A%2012px%3B%22%20valign%3D%22middle%22%3E%3CP%3ELPC1850%26nbsp%3B%20%2F%20Hitex%3C%2FP%3E%3C%2FTD%3E%3CTD%20align%3D%22center%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20font-size%3A%2012px%3B%22%20valign%3D%22middle%22%3E%3CP%3ELPC18xx_HITEX%3C%2FP%3E%3C%2FTD%3E%3CTD%20align%3D%22center%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20font-size%3A%2012px%3B%22%20valign%3D%22middle%22%3E%3CP%3ELPC18xx%3C%2FP%3E%3C%2FTD%3E%3CTD%20align%3D%22center%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20font-size%3A%2012px%3B%22%20valign%3D%22middle%22%3E%3CP%3ELPC18xx_Host%3C%2FP%3E%3C%2FTD%3E%3CTD%20align%3D%22center%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20font-size%3A%2012px%3B%22%20valign%3D%22middle%22%3E%3CP%3ELPC18xx%3C%2FP%3E%3C%2FTD%3E%3CTD%20align%3D%22center%22%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20font-size%3A%2012px%3B%22%20valign%3D%22middle%22%3E%3CP%3ELPC1850%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FDIV%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--55186800%22%20id%3D%22toc-hId-866342176%22%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3EKeil%20uVision%204%20IDE%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSTRONG%3E%E9%85%8D%E7%BD%AE%E6%89%B9%E9%87%8F%E6%9E%84%E5%BB%BA%3C%2FSTRONG%3E%3CBR%20%2F%3E%E7%82%B9%E5%87%BB%E9%A1%B9%E7%9B%AE-%26gt%3B%E6%89%B9%E9%87%8F%E6%9E%84%E5%BB%BA...%3CBR%20%2F%3E%E5%B1%95%E5%BC%80%20BSP%20%E9%A1%B9%E7%9B%AE%E4%BB%A5%E6%98%BE%E7%A4%BA%E9%A1%B9%E7%9B%AE%E7%9B%AE%E6%A0%87%E5%88%97%E8%A1%A8%3CBR%20%2F%3E%E9%80%9A%E8%BF%87%E9%80%89%E4%B8%AD%E7%9B%B8%E5%BA%94%E7%9A%84%E5%A4%8D%E9%80%89%E6%A1%86%E6%9D%A5%E9%80%89%E6%8B%A9%E9%A1%B9%E7%9B%AE%E7%9B%AE%E6%A0%87%3CBR%20%2F%3E%EF%BC%88%E8%A7%81%E4%B8%8B%E8%A1%A8%E4%B8%AD%E7%9A%84%E7%9B%AE%E6%A0%87%E5%88%97%E8%A1%A8%EF%BC%89%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%20CDL%E3%80%81nxpUSBlib_Device%20%E5%92%8C%20Example_AudioOutputHost%20%E9%87%8D%E5%A4%8D%E8%BF%99%E4%BA%9B%E6%AD%A5%E9%AA%A4%3C%2FP%3E%3CDIV%20class%3D%22j-rte-table%22%3E%3CTABLE%20border%3D%221%22%20cellpadding%3D%222%22%20cellspacing%3D%228%22%20style%3D%22border-width%3A%200px%3B%20color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CTBODY%20style%3D%22border-top-color%3A%20%23cccccc%3B%22%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20background-color%3A%20%23ffcc99%3B%20font-size%3A%2012px%3B%22%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20background-color%3A%20%23ffcc99%3B%20font-size%3A%2012px%3B%22%3E%3CP%3EBSP%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20background-color%3A%20%23ffcc99%3B%20font-size%3A%2012px%3B%22%3E%3CP%3ECDL%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20background-color%3A%20%23ffcc99%3B%20font-size%3A%2012px%3B%22%3E%3CP%3EnxpUSBlib_Host%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20background-color%3A%20%23ffcc99%3B%20font-size%3A%2012px%3B%22%3E%3CP%3E%E7%A4%BA%E4%BE%8B_AudioOutputHost%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3CTR%20style%3D%22border-width%3A%200px%3B%22%3E%3CTD%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20background-color%3A%20%23ffcc99%3B%20font-size%3A%2012px%3B%22%3E%3CP%3ELPC1850%26nbsp%3B%20%2F%20Hitex%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20font-size%3A%2012px%3B%22%3E%3CP%3EHITEX1800%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20font-size%3A%2012px%3B%22%3E%3CP%3ELPC18xx%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20font-size%3A%2012px%3B%22%3E%3CP%3ELPC18xx_Host%3C%2FP%3E%3C%2FTD%3E%3CTD%20style%3D%22border%3A%201px%20solid%20%23000000%3B%20border-width%3A%200px%3B%20font-size%3A%2012px%3B%22%3E%3CP%3EHITEX1800%3C%2FP%3E%3C%2FTD%3E%3C%2FTR%3E%3C%2FTBODY%3E%3C%2FTABLE%3E%3C%2FDIV%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId--65689904%22%20id%3D%22toc-hId-855839072%22%3E%3CBIG%3E%3CSTRONG%3E%E7%94%B5%E8%B7%AF%E6%9D%BF%E8%BF%9E%E6%8E%A5%E5%92%8C%E9%85%8D%E7%BD%AE%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FH1%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-624871570%22%20id%3D%22toc-hId-1546400546%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3ELPC18xx_HITEX%EF%BC%88LPC1850%20Hitex%20%E8%AF%84%E4%BC%B0%E6%9D%BF%EF%BC%89%E6%97%A7%E6%AC%BE%20A2%20%E8%AE%BE%E8%AE%A1%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%E5%8E%9F%E7%90%86%E5%9B%BE%3C%2FSPAN%3E.%2FBSP%2Fschematics%2FHITEX_SCM_LPC1850EVA-A2-2.pdf%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%B0%86%20JTAG%20%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%87%E6%9C%89%20X4%20JTAG%20%E7%9A%84%2020%20%E9%92%88%E6%8F%92%E5%BA%A7%3CBR%20%2F%3E%E5%B0%86%20USB%20%E6%89%AC%E5%A3%B0%E5%99%A8%E6%8F%92%E5%85%A5%E6%A0%87%E6%9C%89%20X10%20%E7%9A%84%20A%20%E5%9E%8B%E6%8F%92%E5%BA%A7%3CBR%20%2F%3E%E5%B0%86%209%20%E9%92%88%E4%B8%B2%E8%A1%8C%E7%94%B5%E7%BC%86%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%87%E6%9C%89%20UART%20X1%20%E7%9A%84%E6%8F%92%E5%BA%A7%E3%80%82%E5%B0%86%E6%AD%A4%E7%94%B5%E7%BC%86%E7%9A%84%E5%8F%A6%E4%B8%80%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%E8%BF%90%E8%A1%8C%E7%BB%88%E7%AB%AF%E7%A8%8B%E5%BA%8F%E7%9A%84%20PC%E3%80%82%3CBR%20%2F%3E%E4%B8%BA%E7%94%B5%E8%B7%AF%E6%9D%BF%E4%BE%9B%E7%94%B5%EF%BC%9A%3CBR%20%2F%3E%E5%B0%86%E6%9C%89%E6%BA%90%20USB%20%E7%94%B5%E7%BC%86%E7%9A%84%20B%20%E5%9E%8B%E7%AB%AF%E8%BF%9E%E6%8E%A5%E5%88%B0%E6%A0%87%E6%9C%89%20X13%20%E7%9A%84%E6%8F%92%E5%BA%A7%3CBR%20%2F%3E%E6%88%96%E8%80%85%3CBR%20%2F%3E%E5%90%91%E6%A0%87%E6%9C%89%20X14%20%E7%9A%84%E7%9B%B4%E6%B5%81%E8%BF%9E%E6%8E%A5%E5%99%A8%E6%8F%90%E4%BE%9B%205V%20%E7%94%B5%E6%BA%90%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--1182582893%22%20id%3D%22toc-hId--261053917%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3ELPC18xx_HITEX%EF%BC%88LPC1850%20Hitex%20%E8%AF%84%E4%BC%B0%E6%9D%BF%EF%BC%89%E8%BE%83%E6%96%B0%E7%9A%84%20A3%20%E8%AE%BE%E8%AE%A1%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%3CSPAN%20style%3D%22font-weight%3A%20bold%3B%22%3E%E5%8E%9F%E7%90%86%E5%9B%BE%3C%2FSPAN%3E.%2FBSP%2Fschematics%2FHITEX_Final_LPC1850EVA-A3.pdf%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId--1193085997%22%20id%3D%22toc-hId--271557021%22%3E%3CSTRONG%3E%3CBIG%3EPC%E9%85%8D%E7%BD%AE%3C%2FBIG%3E%3C%2FSTRONG%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%E4%BD%BF%E7%94%A8%E8%BF%90%E8%A1%8C%20Windows%20XP%E3%80%81Vista%20%E6%88%96%207%20%E7%9A%84%20PC%20%E6%98%BE%E7%A4%BA%E5%8F%AF%E4%BD%BF%E7%94%A8%20Teraterm%20%E6%88%96%20Hyperterm%20%E7%AD%89%E7%BB%88%E7%AB%AF%E4%BB%BF%E7%9C%9F%E7%A8%8B%E5%BA%8F%E6%9F%A5%E7%9C%8B%E7%9A%84%E8%BF%90%E8%A1%8C%E6%97%B6%E8%AF%8A%E6%96%AD%E3%80%82%E8%BF%99%E4%BA%9B%E7%A8%8B%E5%BA%8F%E4%B8%AD%E7%9A%84%E6%B3%A2%E7%89%B9%E7%8E%87%E5%BA%94%E8%AE%BE%E7%BD%AE%E4%B8%BA%209600%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId-1294426836%22%20id%3D%22toc-hId--2079011484%22%3E%3CBIG%3E%3CSTRONG%3E%E6%9E%84%E5%BB%BA%E5%B9%B6%E8%B0%83%E8%AF%95%E7%A4%BA%E4%BE%8B%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FH1%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId--636209247%22%20id%3D%22toc-hId-285319729%22%3E%3CBR%20%2F%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3ELPCXpresso%20IDE%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%E5%9C%A8%20IDE%20%E7%9A%84%E9%A1%B9%E7%9B%AE%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E7%AA%97%E5%8F%A3%E4%B8%AD%EF%BC%8C%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%20Example_AudioOutputHost%20%E9%A1%B9%E7%9B%AE%E5%B9%B6%E9%80%89%E6%8B%A9%20Debug%20As-%26gt%3BC%2FC%2B%2B%20MCU%20Application%3CBR%20%2F%3E%E5%9C%A8%20IDE%20%E4%B8%BB%E7%AA%97%E5%8F%A3%E4%B8%AD%E5%8D%95%E5%87%BB%20Run-%26gt%3BResume%20%E5%BC%80%E5%A7%8B%E8%BF%90%E8%A1%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3C%2FP%3E%3CH2%20style%3D%22font-family%3A%20Lato%2C%20sans-serif%3B%20color%3A%20%23e66e08%3B%20font-size%3A%2018px%3B%20background%3A%200%2050%25%20%23ffffff%3B%22%20id%3D%22toc-hId-1851303586%22%20id%3D%22toc-hId--1522134734%22%3E%3CSPAN%20style%3D%22text-decoration%3A%20underline%3B%22%3EKeil%20uVision%204%20IDE%3C%2FSPAN%3E%3C%2FH2%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%E5%9C%A8%E6%89%B9%E9%87%8F%E6%9E%84%E5%BB%BA%E7%AA%97%E5%8F%A3%E4%B8%AD%EF%BC%8C%E6%8C%89%E7%85%A7%E7%BC%96%E8%AF%91%E5%99%A8%E6%9E%84%E5%BB%BA%E9%85%8D%E7%BD%AE%E4%B8%AD%E7%9A%84%E8%AF%B4%E6%98%8E%E9%80%89%E6%8B%A9%E9%A1%B9%E7%9B%AE%E7%9B%AE%E6%A0%87%EF%BC%8C%E7%84%B6%E5%90%8E%E5%8D%95%E5%87%BB%E6%9E%84%E5%BB%BA%3CBR%20%2F%3E%E5%9C%A8%20IDE%20%E4%B8%BB%E7%AA%97%E5%8F%A3%E4%B8%AD%E5%8D%95%E5%87%BB%E2%80%9C%E8%B0%83%E8%AF%95%E2%80%9D-%26gt%3B%E2%80%9C%E5%90%AF%E5%8A%A8%2F%E5%81%9C%E6%AD%A2%E8%B0%83%E8%AF%95%E4%BC%9A%E8%AF%9D%E2%80%9D%EF%BC%8C%E5%8D%95%E5%87%BB%E2%80%9C%E8%B0%83%E8%AF%95%E2%80%9D-%26gt%3B%E2%80%9C%E8%BF%90%E8%A1%8C%E2%80%9D%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3C%2FP%3E%3CH1%20style%3D%22font-size%3A%2026px%3B%20font-weight%3A%20400%3B%20color%3A%20%23333333%3B%20font-family%3A%20Lato%2C%20sans-serif%3B%22%20id%3D%22toc-hId--85233596%22%20id%3D%22toc-hId-836295380%22%3E%3CBIG%3E%3CSTRONG%3E%E6%AD%A4%E7%A4%BA%E4%BE%8B%E5%A6%82%E4%BD%95%E8%BF%90%E8%A1%8C%E4%BB%A5%E5%8F%8A%E8%A6%81%E6%9F%A5%E6%89%BE%E7%9A%84%E5%86%85%E5%AE%B9%3C%2FSTRONG%3E%3C%2FBIG%3E%3C%2FH1%3E%3CP%20style%3D%22color%3A%20%23646464%3B%20font-family%3A%20Arial%2C%20sans-serif%3B%20font-size%3A%2012px%3B%22%3E%E9%A6%96%E6%AC%A1%E8%BF%90%E8%A1%8C%E7%A4%BA%E4%BE%8B%E6%97%B6%EF%BC%8C%E7%BB%88%E7%AB%AF%E7%AA%97%E5%8F%A3%E5%B0%86%E6%98%BE%E7%A4%BA%EF%BC%9A%3CBR%20%2F%3E%E9%9F%B3%E9%A2%91%E8%BE%93%E5%87%BA%E4%B8%BB%E6%9C%BA%E6%BC%94%E7%A4%BA%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3C%2FP%3E%3CP%3E%E5%BD%93%20USB%20%E6%89%AC%E5%A3%B0%E5%99%A8%E6%8F%92%E5%85%A5%E6%97%B6%EF%BC%8C%E7%BB%88%E7%AB%AF%E7%AA%97%E5%8F%A3%E5%B0%86%E6%98%BE%E7%A4%BA%EF%BC%9A%3CBR%20%2F%3E%E5%B7%B2%E6%9E%9A%E4%B8%BE%E9%9F%B3%E9%A2%91%E8%AE%BE%E5%A4%87%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%8C%89%E4%B8%8B%E6%9D%BF%E4%B8%8A%E7%9A%84%E6%8C%89%E9%92%AE%E6%97%B6%EF%BC%8CUSB%20%E6%89%AC%E5%A3%B0%E5%99%A8%E5%B0%86%E5%8F%91%E5%87%BA%E5%93%8D%E4%BA%AE%E7%9A%84%E5%A3%B0%E9%9F%B3%E3%80%82%E5%BD%93%E6%9C%AA%E6%8C%89%E4%B8%8B%E6%8C%89%E9%92%AE%E6%97%B6%EF%BC%8CUSB%20%E6%89%AC%E5%A3%B0%E5%99%A8%E5%B0%86%E4%BF%9D%E6%8C%81%E9%9D%99%E9%9F%B3%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3C%2FP%3E%3CP%3E%E5%BD%93%E6%8B%94%E4%B8%8B%20USB%20%E6%89%AC%E5%A3%B0%E5%99%A8%E6%97%B6%EF%BC%8C%E7%BB%88%E7%AB%AF%E7%AA%97%E5%8F%A3%E5%B0%86%E6%98%BE%E7%A4%BA%EF%BC%9A%3CBR%20%2F%3E%E8%AE%BE%E5%A4%87%E6%9C%AA%E8%BF%9E%E6%8E%A5%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22146753_146753.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22146753_146753.png%22%20style%3D%22width%3A%20276px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F117756i20A978765B66AD32%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22146753_146753.png%22%20alt%3D%22146753_146753.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E146753_146753.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_0.png%22%20style%3D%22width%3A%20276px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F35322i7DFDD95E08E76333%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_0.png%22%20alt%3D%22pastedImage_0.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_0.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎04-25-2016 02:17 PM
更新人:
