voltage to pin
voltage to pin
631 次查看
lpcware
Content originally posted in LPCWare by mcu_programmer on Fri Apr 30 14:35:22 MST 2010
This is not a programming question but an electronics question.
Is it allrigt to connect a PIO pin of the LPC to VCC with the unit not powered up (VCC is not powerering the VCC pins of the LPC)
This will be done momentarily in my application. I can connect a resistor to the pin that will recieve VCC without the LPC being powered.
608 次查看
lpcware
Content originally posted in LPCWare by leon_heller on Sat May 01 09:09:05 MST 2010
No. See the data sheet page 29.
