variables view
variables view
503 次查看
lpcware
Content originally posted in LPCWare by mayotte1 on Fri Sep 17 13:22:53 MST 2010
when I look at the variables panel in lpcxpesso and [I]select[/I] a variable, it also shows on the bottom line an octal view of the same variable as a string. It was originally show as ascii instead of octal. How do I change this back to ascii please?  The Format command doesn't change that bottom line.:confused:
regards;
0 回复数
