uart interrupt
uart interrupt
2,028件の閲覧回数
lpcware
Content originally posted in LPCWare by researchinnovation on Thu Dec 06 04:57:47 MST 2012
Hi..!!
What this part of interrupt will do in UART.
  /* Enable the UART Interrupt */
  NVIC_EnableIRQ(UART_IRQn);
#if CONFIG_UART_ENABLE_INTERRUPT==1
#if CONFIG_UART_ENABLE_TX_INTERRUPT==1
  LPC_UART->IER = IER_RBR | IER_THRE | IER_RLS;    /* Enable UART interrupt */
#else
  LPC_UART->IER = IER_RBR | IER_RLS;    /* Enable UART interrupt */
#endif
#endif
6 返答(返信)
1,940件の閲覧回数
lpcware
Content originally posted in LPCWare by researchinnovation on Tue Dec 11 02:55:19 MST 2012
Quote: vasanth
@researchinnovation,
              There is no research nor innovation in this type of questions. It is a plain old 'C' concept called as preprocessor directives. A simple search in your C book might have provided you the answer.
Please use the expertise available here (forum) for discussing complex topics and problems.
@Vasanth
And you please do not waste your time like this.
Go and  do Eureka instead of wasting your own precious time here.
1,940件の閲覧回数
lpcware
Content originally posted in LPCWare by vasanth on Tue Dec 11 00:38:40 MST 2012
1,940件の閲覧回数
lpcware
Content originally posted in LPCWare by researchinnovation on Mon Dec 10 23:20:06 MST 2012
Quote: Serge
Gray shaded code is not used.
If your IF statement is FALSE with other words: #if CONFIG_UART_ENABLE_INTERRUPT==0
The code is not executed nor compiled.
Thanks a lot....!!!
1,940件の閲覧回数
lpcware
Content originally posted in LPCWare by serge on Mon Dec 10 00:38:19 MST 2012
1,940件の閲覧回数
lpcware
Content originally posted in LPCWare by researchinnovation on Sun Dec 09 20:30:36 MST 2012
Quote: graynomad
What's your question?
If  put #if CONFIG_UART_ENABLE_INTERRUPT==0,#if CONFIG_UART_ENABLE_TX_INTERRUPT==0, then rest of the part of the code becomes gray shade and this part doesn't get executed while compiling.
That is why I want to know in details, what is happening here.
#else
#endif
#endif
1,940件の閲覧回数
lpcware
Content originally posted in LPCWare by graynomad on Sun Dec 09 15:32:58 MST 2012
