uIP file size problem
lpcware
Content originally posted in LPCWare by nkarakotas on Thu May 12 06:20:48 MST 2011
I ported the uIP source from code reds board to work on embedded artists. I used easyWeb emac.c to do the lower level stuff. It works ok but when I create a large file to be displayed such as 3KB it cant send it.
Does this have to do with the uip data buffer not being big enough? Any clues?
Nick
