srec_cat help
srec_cat help
772 次查看
lpcware
Content originally posted in LPCWare by nkarakotas on Sat Oct 20 10:48:58 MST 2012
I need some help on adding a CRC16 on location 0x30C using srec_cat. I used to have a script to do it but cant find it.
I do the following but nothing happens no crc is added:
srec_cat test.bin -binary -exclude 0x030C 0x030D -Fill 0xFF -over test.bin -binary -Cyclic_Redundancy_Check_16_Little_Endian
0x030C -Cyclic_Redundancy_Check_16_XMODEM -o test_crc.bin -binary
0 回复数
