software packages available for development with LPC 2129
591 次查看
lpcware
Content originally posted in LPCWare by suhel on Mon Oct 20 09:18:16 MST 2014
Please share the software packages that are available which can be used for quick software development.
Suhel
580 次查看
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Tue Oct 21 04:11:40 MST 2014
The available software example bundles for LPC2000 parts can be found at:
http://www.lpcware.com/node/11538/59
But I would echo the comments made in your other thread - you really should be considering using a Cortex-M based LPC MCU for your developments/investigations.
LPCXpresso Support
