"unresolved breakpoints"not stopping program
703 次查看
lpcware
Content originally posted in LPCWare by william.vh on Sun Jul 04 14:36:30 MST 2010
I'm using CodeRed 3.4 on WindowsXP with a lpc1343 xpresso board.
Breakpoints show problem "unresolved break point" and do not actually stop the program.
Suggestion on what to check.
Breakpoints are working on Blinky so hardware is OK.
1 回复
696 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Sun Jul 04 23:11:01 MST 2010
Can you remove the *.launch files from your project and then try debugging again. If that doesn't solve the problem, can you say *exactly* what you are doing.
