memory/registers live view
1,310 次查看
Content originally posted in LPCWare by pggordini on Wed May 13 04:40:42 MST 2015
I have installed LPCexpresso
I have connected an LPC8xx emulator and all is ok
I have also connected the target LPC800 via LPC-link2 stand alone probe; all is ok
I can start, stop the target and so on, but I do not find a way to see the values of a memory location or a
range of address while the programm is running.
Is this possible, or I omit some things ?
4 回复数
1,285 次查看
Content originally posted in LPCWare by sergio.scire on Mon May 18 06:53:42 MST 2015
Quote: lpcxpresso-support
No, it is not possible.
Dear NXP support team,
why don't you explain how to fix the problem?
Sometimes I find your answers useless
1,285 次查看
Content originally posted in LPCWare by R2D2 on Wed May 13 06:32:49 MST 2015
Did you read http://www.lpcware.com/content/faq/lpcxpresso/trace-overview  :quest:
1,285 次查看
Content originally posted in LPCWare by pggordini on Wed May 13 06:29:55 MST 2015
ok, may it be possible with a j-link2 probe and am M4 target CPU ?
1,285 次查看
Content originally posted in LPCWare by lpcxpresso-support on Wed May 13 05:26:31 MST 2015
