lpcxpresso and mbed
lpcxpresso and mbed
1,445 次查看
lpcware
Content originally posted in LPCWare by mayotte1 on Tue Jan 12 09:32:35 MST 2010
If we cut apart the lpcxpresso board, can we plug in the mbed board and used the lpcxpresso debug tools and treat the mbed as just another lpc1768 board?
1,403 次查看
lpcware
Content originally posted in LPCWare by NXP_USA on Sun Jan 24 23:18:13 MST 2010
The mbed board does not have debugger connections on it, so it cannot be connected to an external debugger such as the LPCXpresso LPC-LINK. However the LPCXpresso IDE can generate binary files which can be programmed into the mbed board over the USB connection.
1,403 次查看
lpcware
Content originally posted in LPCWare by annodomini2 on Tue Jan 19 14:31:03 MST 2010
You can't access the JTAG pins on the mbed as they are used by the 'magic' chip to program the LPC1768 on reset of the mbed
1,403 次查看
lpcware
Content originally posted in LPCWare by NXP_USA on Tue Jan 12 10:35:33 MST 2010
You can cut apart the LPCXpresso board and use the LPC-LINK section with most LPC1768 development boards such as the RBD1768 from Code Red as long as you stay within the 128KB flash usage limit. In theory one could use the mbed board, but the mbed board does not have the JTAG/SWD signals brought out to the DIP pinout.
http://code-red-tech.com/lpc1768-development-kit.php
