Content originally posted in LPCWare by domen on Thu May 20 13:52:42 MST 2010
Anyone managed to get USB running with main clock instead of USB PLL?
I've set main clock to 48 MHz, USBCLKSEL=1, USBCLKUEN toggle, USBCLKDIV=1. Doesn't seem to work.
Btw. none of the examples use USBCLKUEN toggle (and manual says it's needed after USBCLKSEL is set)
Btw2. none of the examples set USBCLKDIV to 1 (manual says 0 is the default, and that means disabled?!)
