inline Assembly - How To ?
3,027件の閲覧回数
lpcware
Content originally posted in LPCWare by behzat_c on Tue May 24 04:29:45 MST 2011
Hey Everyone!
Is there any tutorial or example cod snippet where i can look up for how to embed assembly code in to C program.
I know that there is an asm(" ... ") function to that but i mean how can i access a variable or array element defined in C within that assembly program?
Also,
is there any special instruction set for NXP series or just the classic Cortex M3 instruction set apply here?
6 返答(返信)
2,860件の閲覧回数
lpcware
Content originally posted in LPCWare by larryvc on Tue May 24 10:27:48 MST 2011
I realize that the post I referred you to does not actually answer your question.  But it does show how to use a separate assembly file that is callable from C.
Now you need to work on the accessing a variable or array element part.
Sorry I can't be of more help with that.
Larry
2,860件の閲覧回数
lpcware
Content originally posted in LPCWare by TheFallGuy on Tue May 24 09:50:27 MST 2011
Quote: behzat_c
I also waiting for someone to tell how can i access the variables declared in C from assembly.
This is a good place to start:
http://www.ethernut.de/en/documents/arm-inline-asm.html
2,860件の閲覧回数
lpcware
Content originally posted in LPCWare by whitecoe on Tue May 24 09:49:43 MST 2011
There are quite a few previous posts about using assembly within LPCXpresso. As a starting point try....
http://lmgtfy.com/?q=assembly+site%3Aknowledgebase.nxp.com
HTH!
2,860件の閲覧回数
lpcware
Content originally posted in LPCWare by larryvc on Tue May 24 09:45:54 MST 2011
behzat_c,
I'm curious to know why you need inline assembler?
Also this post has an example for the LPC1343 that you can get ideas from:
http://knowledgebase.nxp.com/showpost.php?p=369&postcount=11
Larry
2,860件の閲覧回数
lpcware
Content originally posted in LPCWare by behzat_c on Tue May 24 09:40:17 MST 2011
Quote: larryvc
To my knowledge there are no special instructions.  I'm assuming you are still talking about an LPC1769, the Cortex M3 instruction set does apply.
Yes, I'm still talking about LPC1769. Thanks for the info.
2,860件の閲覧回数
lpcware
Content originally posted in LPCWare by larryvc on Tue May 24 09:30:47 MST 2011
