how to share variables between C and HTML/Java
jameshardin
I have LPC4088 and ea developers kit. I am looking at the supplied examples for web server and TCP echo without RTOS. I cant figure out how to share information between a web page and the C application. can someone help?
Tags (2)
soledad
Hi James,
LPCOpen contains examples like you need.
LPCOpen Libraries and Examples|NXP
the lwip_tcpecho_sa: this example shows how to use the raw API with the LWIP contrib TCP Echo example using the 17xx/40xx LWIP MAC and PHY drivers without and RTOS.
the webserver: The LWIP HTTP Server example demonstrates the HTTP Server functionality using LWIP ethernet stack (without RTOS).
I hope this helps,
Sol
