how to install plugin
1,609件の閲覧回数
Content originally posted in LPCWare by renan on Fri Dec 11 08:10:59 MST 2009
I would like to know how to install a plugin, since we are talking about an IDE based on eclipse. Using red suite this is possible through Help menu.
Thanks in advance,
Renan
3 返答(返信)
1,482件の閲覧回数
Content originally posted in LPCWare by CodeRedSupport on Sat Dec 12 07:20:47 MST 2009
As written below, this is not possible with LPCXpresso, unless subversion can be installed using the dropins folder method.
You can, of course, use an external tool, such as TortoiseSVN.
1,482件の閲覧回数
Content originally posted in LPCWare by Jan van den Borst on Fri Dec 11 17:53:53 MST 2009
I want to install subclipse to be able to use subversion. How can this be done?
Jan
1,482件の閲覧回数
Content originally posted in LPCWare by CodeRedSupport on Fri Dec 11 08:46:17 MST 2009
LPCXpresso is a simplified version of Eclipse and does not support the plugin user interface.
However, it is possible to add a plugin by using the 'dropin folder' method. See the Eclipse website for details on how to do this.
Red Suite, of course, fully supports plugins.
