gsm interfacing using lpc 1343
lpcware
Content originally posted in LPCWare by hariprasad.vit on Tue Apr 02 04:46:27 MST 2013
hello guys,
        I'm doing my second sem project which contains interfacing lpc 1343( which is available in my lab ) with gsm. I'm a newbie to this area and i need some help plzz. .
     can any one tell me how to program gsm in llc 1343 and where can i find the library files for coding the gsm. .someone plz tell me i need this very badly
thanks in advance
lpcware
Content originally posted in LPCWare by serge on Mon Apr 15 23:51:21 MST 2013
We are willing to help solve some problems. What we don't do here is writing the program for you.
One tip: look at the the AT-commands for your cellphone. This is a good starting point. The AT-commands for your cellphone will probably be just a little different.
If you want a library you should write your own.
lpcware
Content originally posted in LPCWare by hariprasad.vit on Mon Apr 15 03:01:50 MST 2013
some one plz help me . .. I  was stuck in this part
