global variables
global variables
lpcware
Content originally posted in LPCWare by RatonVaquero on Wed Feb 24 17:17:57 MST 2010
has anyone found a way to display global variables in the variables tab?
I can only see the local variables....
thanks
lpcware
Content originally posted in LPCWare by RatonVaquero on Fri Feb 26 08:27:58 MST 2010
SOLVED!
The trick was to eliminate the '--gc-sections' from the linker. After that, close the variables tab and re-open the variables tab, then the option to add global variables is enabled.
thanks!
lpcware
Content originally posted in LPCWare by CodeRedSupport on Thu Feb 25 15:41:00 MST 2010
If the global variables option is greyed out in the Variables view, then you could try closing the variables view, then reopening it from the "Window -> Show view" menu.
This should reset the variables view, and you should then hopefully be able to add your global variables to it.
CodeRedSupport.
lpcware
Content originally posted in LPCWare by renan on Thu Feb 25 14:19:21 MST 2010
Sorry, I cannot see whats grayed out. I cannot zoom your image to see where is.
Renan
lpcware
Content originally posted in LPCWare by RatonVaquero on Thu Feb 25 11:42:15 MST 2010
In my case, the global variables option is grayed out. I will try the "--gc-sections" option.
[IMG]http://img297.imageshack.us/img297/3624/globalvargrays.jpg[/IMG]
lpcware
Content originally posted in LPCWare by renan on Thu Feb 25 10:31:34 MST 2010
Quote: CodeRedSupport
If you remove all globals from the view, and add them back again - does that solve the problem?
When I remove  the variable that I removed from my source, stop debuging and restart debuging it solves. I will try your way too.
If not, can you try removing the "--gc-sections" option from the link  step of your build and seeing if that helps?
I'm already not using this option.
Renan
lpcware
Content originally posted in LPCWare by CodeRedSupport on Thu Feb 25 09:42:53 MST 2010
Renan,
CodeRedSupport
lpcware
Content originally posted in LPCWare by renan on Thu Feb 25 07:25:18 MST 2010
I would like to report a possible bug in this view.
I have created a global variable and added it to variables view. Then I removed the variable from my source code and did not remove it from the view.
I have other variables too in the view.
The problem is that none of the variables that are after the variable I deleted from my source code are beeing refreshed.
See the selected variable value = 12, then down it is showing 13 '\r'.
[IMG]http://img692.imageshack.us/img692/3496/variableserror.th.jpg[/IMG]
Renan
lpcware
Content originally posted in LPCWare by CodeRedSupport on Thu Feb 25 02:16:16 MST 2010
Right click on the variables view, and select "add global variables". You then need to select which globals you want to display.
CodeRedSupport
