generate .bin file
generate .bin file
lpcware
Content originally posted in LPCWare by krishna.mohan on Mon Oct 19 23:59:35 MST 2015
Could you tell me how to generate bin file.
Many errors were showing in Release build setting. But there were no such errors in Debug Build mode.
Krishnamohan.
lpcware
Content originally posted in LPCWare by R2D2 on Tue Oct 20 02:16:14 MST 2015
Read:
https://www.lpcware.com/content/faq/lpcxpresso/linker-cannot-find-library
lpcware
Content originally posted in LPCWare by krishna.mohan on Tue Oct 20 02:03:31 MST 2015
Attached the snap shots.
Could you tell me the path of bin file in the project directory.
Krishanmohan
lpcware
Content originally posted in LPCWare by mysepp on Tue Oct 20 00:02:38 MST 2015
Can you post your errors here?
No bin (or hex) is generated when there are errors in build and/or link.
