gdb-sim simulation
gdb-sim simulation
808 次查看
Content originally posted in LPCWare by micronpn on Tue Dec 14 05:44:52 MST 2010
I would understand if it is possible to debug (partially) an application using LpcXpresso IDE without connecting a real hardware board. Actually I am using dual targeting (GCC for arm anf for mingw) but of corse I can't see peripheral registers and so on.
787 次查看
Content originally posted in LPCWare by CodeRedSupport on Tue Dec 14 06:12:53 MST 2010
No - LPCXpresso IDE supports the debug of actual hardware only.
