__fp16 (Halfprecision floating point) problem
1,068 次查看
lpcware
Content originally posted in LPCWare by bap on Tue May 15 09:28:06 MST 2012
I have the LPC1114 LPCXpresso board and LPCXpresso v4.2.2 [Build 275]. In my code I use the half precision floating point (__fp16). I have set the compiler flag -mfp16-format=ieee, but when linking I get the error: "undefined reference to `__aeabi_f2h'." I probably only need to set a linker flag, but I don't know which one and I haven't found the solution yet. So if anyone could point me in the right direction it would be much appreciated.
1,015 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Tue May 15 09:49:55 MST 2012
The issue is that half precision floating point is not supported in Redlib. You should just switch to Newlib and you will be able to link.
