documentation for C functions
617 次查看
lpcware
Content originally posted in LPCWare by unnati on Fri Jun 04 06:26:32 MST 2010
hi,
i want detailed documentation on C functions supported by LPCxpresso - code red.
1 回复
608 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Sat Jun 05 07:23:06 MST 2010
An introduction to the two C libraries - Redlib and Newlib - provided as part of the LPCXpresso IDE can be found at:
http://lpcxpresso.code-red-tech.com/LPCXpresso/node/30
This also contains a few links to general information on C libraries on the web. But if you google, you will find a lot of other similar sites too.
CodeRedSupport
