Content originally posted in LPCWare by dragilla on Thu Nov 17 08:04:58 MST 2011
So LPC-link uses SWD, and 4 pins is enough: Reset, SWCLK, SWDIO, GND.
Thank you very much :)
Another one: how much power can I safely drain from the 3v3-out when the board is still in one piece (usb-powered)? I guess the limitation here is the voltage regulator (5 to 3v3) but I don't know how much the target board itself uses...
I have already connected the 3v3-out to my imu 6deg board. Now I wanted to connect my gps, but this one uses 100mA, so I'm affraid a bit :)
