Windows 8
Windows 8
lpcware
Content originally posted in LPCWare by ex-kayoda on Fri Nov 02 02:44:18 MST 2012
Is LPCXpresso 4.3.0 running on Windows 8 PRO/32bit or is my machine just bad-tempered today :confused:
lpcware
Content originally posted in LPCWare by ex-kayoda on Fri Nov 02 16:11:42 MST 2012
Quote: kayoda
Build is working fine, so I think it's something related to driver or driver access.
Deleting AVIRA Beta solves this Bluescreens :)
lpcware
Content originally posted in LPCWare by ex-kayoda on Fri Nov 02 14:34:28 MST 2012
At the moment I'm seeing this new bluescreen with smiley :) while a debug session is started.
I'll do a few  tests with this desktop and report the result later.
lpcware
Content originally posted in LPCWare by CodeRedSupport on Fri Nov 02 13:19:53 MST 2012
Must be you machine, because it all works here. We have been running Windows 8 pre-release for several months and we have tested with the final release too.
If you are having problems, please tell us what they are, so we can investigate.
