Why does LPCXpresso default to M0 for LPC11U68 projects?
1,596 次查看
muis
I noticed that projects created for LPC11U68 default to Cortex M0 (instead of Cortex M0+).
Even if I change it manually to M0+ everywhere, the value is resetted to M0 after saving.
Is there a reason behind this? Because as far as I'm aware the LPC11U68 contains the M0+?
标签 (2)
1,409 次查看
lpcxpresso_supp
This is really just for legacy reasons, related to us starting to support Cortex-M0+ parts before GCC had an explicit Cortex-M0+ option. But is actually doesn't matter because for GCC from a target cpu viewpoint CM0 and CM0+ are currently the same.
LPCXpresso Support
