Content originally posted in LPCWare by acelink1 on Tue Feb 18 23:37:34 MST 2014
Hi Guys, I've created and assembler file called Test.S and used the build command to build the assembly file in Xpresso.
After building their should be a file called Test.bin or Test.hex in the workspace directory but I can't seem to find it.
It does create a file called Test.axf and Test.o
Do I have to setup something in Xpresso to generate the .bin or .hex files?
and thanks for your support guys :)
Pete :)
