WAKEUP External PU
WAKEUP External PU
lpcware
Content originally posted in LPCWare by dfaucher on Wed Jul 21 13:14:03 MST 2010
I'm working on a portable solution (battery powered).  I want to use deep power-down mode when the system is powered by the battery and idle. The user manual says "This pin must be pulled HIGH externally to enter Deep power-down mode".  How much current is needed by the WAKEUP pin to consider it as a HIGH level? I want to reduce down the pull-up current to the minimum to not drain my battery to fast, any idea?
DF
Original Attachment has been moved to: 1100558_lpc_swu.zip
