Unsupported LPC models
716 次查看
Content originally posted in LPCWare by juxas on Fri Oct 29 04:39:25 MST 2010
Is it possible to use LPCXpresso with unsupported models(to be precise LPC2138)? Does it completely not support it or just some of the features?
Thank you.
708 次查看
Content originally posted in LPCWare by CodeRedSupport on Fri Oct 29 05:15:01 MST 2010
In the free LPCXpresso product, you can generate code for unsupported parts, but you can't debug .
The full range of parts is supported in the upgrade product Red Suite NXP Editions, which cost $256 for 256k limited or $512 for 512k limited version. See http://www.code-red-tech.com/red-suite-3-nxp.php
