The LPCXpesso Compiler opttion
lpcware
Content originally posted in LPCWare by shiggy on Mon Oct 07 07:20:08 MST 2013
Hi Everyone!
I am using the LPCXpresso V5.0.14 for LPC1830 MCU.
When you change the code of C into a machine language,
please teach me the setting method most faithfully changed
into a machine language in(from) the code of c, without optimizing.
If you give me any comment or answer, I am very happy.
Shiggy
lpcware
Content originally posted in LPCWare by shiggy on Tue Oct 08 01:39:48 MST 2013
Hi Chris Burrows-san!
Thanks for your kind response.
Shiggy
lpcware
Content originally posted in LPCWare by cfbsoftware on Tue Oct 08 00:26:11 MST 2013
-O0
Reduce compilation time and make debugging produce the expected results. This is the default.
