Switching the selected C library to use printf() function
lpcware
Content originally posted in LPCWare by AMIWallace on Sun Feb 15 21:36:05 MST 2015
I installed the LPCXpresso_7.6.2_326 IDE on my laptop(Win 8 OS) and tried to fix the compiler error about the printf function by follow the instructions in http://www.lpcware.com/content/faq/lpcxpresso/switching-selected-c-library, but I can't find "Target under MCU Linker" in step 4. Is there any solution about this issue?
Thanks!
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Mon Feb 16 01:43:00 MST 2015
The simplest way to change the library type is to follow the first part of the instructions. Use the Quickstart panel and select Quick Settings -> Set library/header type, and choose the library type.
I notice that the other instructions were slightly out of date, and they have been updated to reflect the latest version of LPCXpresso - thanks for pointing this out.
