Single PWM
Single PWM
Content originally posted in LPCWare by blasiis on Mon Mar 29 01:52:28 MST 2010
I use LPCxpresso developper system with LPC1768 and I find a example for single pin PWM output (no motor control).
I want PWM out on P2.2
I have set the PINSEL4 but don't run.
LPC_PINCON->PINSEL4    = (0x00000010);
Content originally posted in LPCWare by rmteo on Mon Mar 29 07:43:49 MST 2010
There is a similar example here http://knowledgebase.nxp.com/showthread.php?t=241
