Setting Diconnect Behaviour
lpcware
Content originally posted in LPCWare by rmteo on Sun Mar 07 08:38:30 MST 2010
There have been several questions regarding the procedure to set the disconnect behaviour of the LPCXpresso.  Do this:
a.  Right click on the Project and select "Debug As", "Debug Configurations..."
b.  When the Dialog Box appears, Select your project (Debug or Release) then click on the "Debugger" tab.
c.  Select the appropriate "Disconnect behavior" under "Script values"
[IMG]http://home.earthlink.net/%7Ermteo/sitebuildercontent/sitebuilderpictures/a_70b.jpg[/IMG]
lpcware
Content originally posted in LPCWare by CodeRedSupport on Sun Mar 07 13:55:57 MST 2010
The instructions in the knowledgebase have been updated to include screenshots
lpcware
Content originally posted in LPCWare by LynnF on Sun Mar 07 09:00:08 MST 2010
Thanks, finally something not written in "geek"
Your help is appreciated
