Resetting Project Explorer defaults
1,495件の閲覧回数
lpcware
Content originally posted in LPCWare by LynnF on Sun Mar 07 08:13:52 MST 2010
Is there a way to reset the Project Explorer default look so it matches what it looks like on page 12 of the getting started menu?
Or how do you turn on the various tabs?
I am struggling to find the "Disconnect behavior"
The explaination in Code Read knowledgebase doesn't make much sense with regards to the instructions given.
2 返答(返信)
1,469件の閲覧回数
lpcware
Content originally posted in LPCWare by CodeRedSupport on Sun Mar 07 13:54:35 MST 2010
1. Project Explorer.
You don't explain what is different from the Getting Started. If we could see what the difference is, we might be able to explain how to get it back.
2. Disconnect behavior.
We have update the instructions with a couple of screenshots to help.
1,469件の閲覧回数
lpcware
Content originally posted in LPCWare by martinjm on Sun Mar 07 12:19:56 MST 2010
Me too - see my post as well.  At least it's not just me ... ;)
