RedlinkAPI: Wire Ack Fault - target connected?
1,245 次查看
Content originally posted in LPCWare by hchen021 on Sat Jan 10 09:16:10 MST 2015
Failed to connect LPC4330-Xplorer
Environment;
LPCXpresso 7.5.0_254
LPC link 2.
Lpc4330 Xproler.
4330Xproler is connected to LPC link2 with 10 pin lines. the power of LPC4330 Xplorer is OK.
This is the error log:
Error in final launch sequence
Error: Error reported by server (redlinkserv.exe):
Redlink Server has been terminated and will be restarted.
Please restart your debug session.
If the problem recurs, please power cycle your debug probe and restart LPCXpresso.
834 次查看
Content originally posted in LPCWare by TheFallGuy on Sat Jan 10 16:12:29 MST 2015
Try this
http://www.lpcware.com/content/faq/lpcxpresso/target-marked-not-debuggable
