RedChannel Tab plug-in fails to load
605 次查看
lpcware
Content originally posted in LPCWare by robert.palmer on Wed Feb 22 15:45:36 MST 2012
I'm not sure what the "RedChannel" tab in LPCXpresso is for, but I get the following error when I select this tab:
Could not create the view: Plug-in com.crt.lite.brand was unable to load class com.crt.config.browserview.RedInfoView
Is this something I need to concern myself with?  What is supposed to be shown in this tab?  How do I fix the issue?
1 回复
597 次查看
lpcware
Content originally posted in LPCWare by TheFallGuy on Wed Feb 22 16:02:46 MST 2012
it is irrelevant. You can ignore the errors.
