Red Suite 4 JTAG configuration
lpcware
Content originally posted in LPCWare by dhill on Thu May 31 10:15:17 MST 2012
I am using Red Suite 4 to debug a LPC2368 target. When I attempt to download the software to the target I get the following error in a JTAG Configuration popup.
IR Length required.
TAP Id = 0xfffffffe
IR Length = ?
When I click "Edit JTAG configuration" on the Debugger tab in the Debug Configurations window, I get "No JTAG targets found".
Any suggestions on what I'm doing wrong?
Thanks.
lpcware
Content originally posted in LPCWare by TheFallGuy on Thu May 31 13:47:43 MST 2012
Do you have multiple devices on the scan chain?
See
http://support.code-red-tech.com/CodeRedWiki/MultipleJtagDevices
