Read adc module repeatedly , will it affect adc peripheral in long run
662 次查看
lpcware
Content originally posted in LPCWare by aamir ali on Fri May 10 02:13:22 MST 2013
Will repeatedly reading adc peripheral in infinite module affects the hardware in long run.
I have task which has to run after certain adc value comes.
So I keep on reading adc value in infinite loop.
I am using lpc1317-64P with 72Mhz core clock
1 回复
646 次查看
lpcware
Content originally posted in LPCWare by leon_heller on Fri May 10 03:50:02 MST 2013
Of course not! What do you think will happen?
