`RamLoc32' overflowed - error at compiling
lpcware
Content originally posted in LPCWare by Doini on Thu Mar 07 13:38:41 MST 2013
I have the following error when I compile:
[SIZE=2]Application.axf section `.bss' will not fit in region `RamLoc32'
[SIZE=2]region `RamLoc32' overflowed by 3472 bytes
[SIZE=3]I would appreciate any help about what I should do.[/SIZE]
[SIZE=3][/SIZE]
[SIZE=3]Thank you,[/SIZE][/SIZE][/SIZE][SIZE=3]Doini[/SIZE]
lpcware
Content originally posted in LPCWare by Ex-Zero on Thu Mar 07 16:11:42 MST 2013
Reduce your bss ;) It's 3472 bytes too large :eek:
See: http://www.support.code-red-tech.com/CodeRedWiki/FlashRamSize?highlight=%28bss%29
