Project path error
Project path error
786件の閲覧回数
Content originally posted in LPCWare by jdurand on Sun Jul 15 21:14:26 MST 2012
I'm getting warnings about invalid project path.
I'm running version 2.2.3.255 on Ubuntu Linux 12.04
The warning messages starts off "invalid project path: include path not found (/usr/local/lpcxpresso_4.2.2_238/...
I can't figure out where it has that path set, obviously it should be 4.2.3.255.
If I create a new workspace and let the wizard put a new project in there it now works fine.
I tried this on 3 different computers.
777件の閲覧回数
Content originally posted in LPCWare by jdurand on Sun Jul 15 21:56:22 MST 2012
I hadn't found that thread, but I just did fix it by creating a new workspace and importing everything into it.
777件の閲覧回数
Content originally posted in LPCWare by ex-kayoda on Sun Jul 15 21:19:32 MST 2012
Did you delete your SC file already?
See: http://knowledgebase.nxp.com/showthread.php?t=2556
and http://support.code-red-tech.com/CodeRedWiki/InvalidProjPath
