Programming OM13069 Quick-Jack
1,265件の閲覧回数
Content originally posted in LPCWare by bpolcawich on Tue Jul 29 07:11:40 MST 2014
Before I purchase an LPC-Link 2 I want to make sure that will in fact be able to program the OM13069 Quick-Jack with LPC812 series MCU.
Brandon
3 返答(返信)
1,209件の閲覧回数
Content originally posted in LPCWare by lpcxpresso-support on Tue Aug 05 07:25:05 MST 2014
Please read the FAQ:
http://www.lpcware.com/content/faq/lpcxpresso/target-marked-not-debuggable
1,208件の閲覧回数
Content originally posted in LPCWare by bpolcawich on Tue Aug 05 06:25:09 MST 2014
I purchased the link 2.  I am not trying to load the example code for the quick jack to make sure I am using the link 2 correctly.  However when I try to load the file onto the quick jack board I get error that says:
02: Failed on connect: Ep(01). Target marked as not debuggable.
Am I doing something wrong?
1,208件の閲覧回数
Content originally posted in LPCWare by lpcxpresso-support on Tue Jul 29 12:04:25 MST 2014
LPC-Link2 can you used to debug any LPC device with a JTAG or SWD conector
