Programming Code
Programming Code
lpcware
Content originally posted in LPCWare by anchalia.vivek on Wed Jul 30 10:28:12 MST 2014
Hello ,
Design Description
I am using a LPC812 microcontroller. I have antenna in my design and NTAG I2c . I have a temperature sensor in my design.
The voltage generated by energy harvesting is being used to read out the temperature.
Query :
I have the model source file and required project file for my project described now. My software apk also has a energy harvested option to see the amount of energy generated. I need the source code or a way to actually see the energy being harvested.
Thank you,
Vivek Kumar
