Program download problem
lpcware
Content originally posted in LPCWare by abhilash.bidari on Sun Mar 04 06:40:48 MST 2012
Iam getting this below erro
15: Target error from Commit Flash write: Et: Flash driver not ready.
lpcware
Content originally posted in LPCWare by dadalolo on Fri Jul 13 20:59:37 MST 2012
the answer is simple : poorly written tool
It hangs on me now and then for no reasons. Had to Reboot PC - sometimes more than once.
lpcware
Content originally posted in LPCWare by whitecoe on Mon Mar 05 04:47:20 MST 2012
So have you tried searching previous threads and looking at the FAQs?? This sticky post at the top of the forum gives the appropriate links...
http://knowledgebase.nxp.com/showthread.php?t=2182
And this previous post may give you a few things to start off trying...
http://knowledgebase.nxp.com/showpost.php?p=9294&postcount=5
HTH!
lpcware
Content originally posted in LPCWare by abhilash.bidari on Mon Mar 05 01:36:31 MST 2012
1. LPC1114
2. There is no problem with the usb cable.
3. I tried disconnect and reconnect, but no use.
lpcware
Content originally posted in LPCWare by serge on Mon Mar 05 00:59:01 MST 2012
1. Wich lpcxpresso board do you use? :confused:
2. Use a very good quality USB cable ;)
3. Disconnect and reconnect the lpcxpresso board :D
4. Search the forum since this topic has been around for some time and you should find a lot of threads where this problem is discussed! :eek:
