Problem with library
lpcware
Content originally posted in LPCWare by ccavallieri on Mon May 25 05:32:27 MST 2015
I'm calling a library named "hardware.h" but LPCXpresso says "no such file or directory".
It's interesting, because it was everything OK, then suddenly this error came up.
Does anyone could help me?
Thanks.
lpcware
Content originally posted in LPCWare by ccavallieri on Mon May 25 06:43:34 MST 2015
I can't believe it was about it.
Thank you very very much, I'm new with all of this stuff.
Regards from Brazil.
lpcware
Content originally posted in LPCWare by LabRat on Mon May 25 06:39:52 MST 2015
Quote: ccavallieri
:D
Your includes are working  :)
Your ProjName variable is wrong:
[img=822x391]http://www.lpcware.com/system/files/proj.JPG[/img]
Change it to 'chicago4094' and your include path is correct....
lpcware
Content originally posted in LPCWare by ccavallieri on Mon May 25 06:19:13 MST 2015
lpcware
Content originally posted in LPCWare by LabRat on Mon May 25 05:50:17 MST 2015
Quote: ccavallieri
Take a look at the project.
:quest:
That's no project, that's a C-file  :O
http://www.lpcware.com/content/faq/lpcxpresso/how-importexport-projects
lpcware
Content originally posted in LPCWare by ccavallieri on Mon May 25 05:43:50 MST 2015
Yes, this is what I mean, including a header.
lpcware
Content originally posted in LPCWare by LabRat on Mon May 25 05:37:00 MST 2015
:quest:
Nope, you are including a header  :)
http://www.lpcware.com/content/faq/lpcxpresso/creating-linking-library-projects
Without your project it's difficult to understand your problem...
