Path directory problem
lpcware
Content originally posted in LPCWare by prasadsrkrec on Wed May 30 02:35:55 MST 2012
[B]I started LPCxpresso Progrraming My device part number is lpc1343....Initially  i imported One example project (blinky) and debug it.. if i simulate it doesn't shows errors but it shows warnings regarding path directory,..any one give me some guidance on that ....[/B]
lpcware
Content originally posted in LPCWare by lyncas on Wed May 30 06:10:09 MST 2012
can you list the specific warnings.
Typically to run "blinky" you will need to link against the CMSISv1p30_LPC13xx library
