PWM on LPC1751
PWM on LPC1751
Content originally posted in LPCWare by tinto on Wed Mar 21 03:44:50 MST 2012
Hai...
Is there any way to generate 6 PWMs with different frequencies using LPC1751?
I don't need to change the duty cycle. I just need to have independent frequencies in each channel.
Content originally posted in LPCWare by gbm on Wed Mar 21 07:02:01 MST 2012
AFAIR, you may generate one PWM frequency in hardware using PWM and 3 using MCPWM. If two more are needed, you can do it in software using two other timers. No problem if you don't require extremely small jitter.
Content originally posted in LPCWare by tinto on Wed Mar 21 05:10:45 MST 2012
Ok, I agree with that.
But any simple method to generate 6 PWMs with different frequencies in software?
I need frequency below 5kHz only.
Content originally posted in LPCWare by Ex-Zero on Wed Mar 21 04:08:29 MST 2012
No :eek:
Answered already in: [U]http://knowledgebase.nxp.com/showthread.php?t=2392[/U]
