Newbie: How to flash AXF file to MCU using ISP method ?
1,172件の閲覧回数
lpcware
Content originally posted in LPCWare by Karthik Venkatesh on Mon Nov 30 23:18:08 MST 2015
I have LPCxpresso IDE and custom target board having LPC812.
Should I need external tool like Flash Magic in order to program the LPC812 flash in ISP method ?
Doesnt LPCxpresso have in-built flash tool for ISP method ?
Please clarify.
Thanks and regards,
Karthik
1,000件の閲覧回数
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Tue Dec 01 02:37:49 MST 2015
LPCXpresso IDE cannot talk directly via an ISP serial port connection, you need a debug probe. Alternatively for ISP connections, Flash Magic is the recommended tool to use.
Anyway, I strongly suggest that you get yourself an LPC-Link2, so that you can download and debug your code directly from LPCXpresso IDE...
https://www.lpcware.com/lpclink2
You might want to consider an off-the-shelf board with a built in debug probe too for early development work too...
https://www.lpcware.com/LPCXpressoBoards
And given your questions from the last few days, I strongly suggest that you take the time to watch the "Rapid Embedded Development with LPCXpresso" video at:
https://www.lpcware.com/lpcxpresso
LPCXpresso Support
