Move project to different location and compile error
lpcware
Content originally posted in LPCWare by lenguyen on Wed Feb 19 08:57:53 MST 2014
we create a workspace with a project using board 4078 library. This workspace is under c:\workspace folder. In this workspace there are two project, first is for board library with  include all board and chip library under c:\ncp\lpcopen\.... and second is test which is using board library. Everything compile and link OK. Then we decided to move whole workspace to under a folder c:\project\... then there is problem when we recompile the project. it complains about build error. Here's an error:
* Make: *** No rule to make targe `C:/project/nxp/lpcopen/software/lpc_core/lpc_ip/acmp_001.c', needed by `ip/acmp_001.o. Stop.
Any body has the same problem ?
Thank you for your input.
ln
lpcware
Content originally posted in LPCWare by lenguyen on Wed Feb 19 10:04:11 MST 2014
Thank you
ln
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Wed Feb 19 09:26:55 MST 2014
Please read this FAQ:
http://www.lpcware.com/content/faq/lpcxpresso/how-importexport-projects
