Linker Issues with lpcXpresso
576 次查看
lpcware
Content originally posted in LPCWare by mariyar on Sun Feb 02 11:32:36 MST 2014
Hello everyone,
I am trying to build my CMSIS library in the
IDE but is showing some strange error again and again.
make: *** [src/core_cm3.o] Error 3
it is the error it is showing on building CMSIS core library. Iam unable tol locate the error in which file it is giving.
Searched for it in its makefile but didn find nething.
Please if any one can help regarding the same.
Thanking you
1 回复
569 次查看
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Mon Feb 03 01:48:19 MST 2014
It is very hard to tell from the minimal information you have provided as to what might be happening here. My best guess would be as per this FAQ:
http://www.lpcware.com/content/faq/lpcxpresso/linker-cannot-find-library
If this doesn't help, then do  a clean of your project, then build again and look in the build log…
http://www.lpcware.com/content/faq/lpcxpresso/build-console
What does this show you?
LPCXpresso Support
