LPCxpresso importing LPCopen
1,366件の閲覧回数
lpcware
Content originally posted in LPCWare by reedomneck on Wed May 18 22:48:43 MST 2016
I am new to this LPC and LPCxpresso IDE.
I have downloaded LPC open projects and imported into IDE. When i compile i am getting No rule to make error.
And i am not able to open the source files in IDE i am getting Error retrieving content description for resource
Can anyone help me how to use/import and compile
5 返答(返信)
1,333件の閲覧回数
lpcware
bump
1,333件の閲覧回数
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Thu May 19 06:59:20 MST 2016
Please respond with the LPCOpen library name you're attempting to import. Are you using a non-English locale? We've seen no problems like you describe, and (other than yours) there have been no related problem reports.
Thanks and regards,
LPCXpresso Support
1,333件の閲覧回数
lpcware
Content originally posted in LPCWare by reedomneck on Thu May 19 02:12:49 MST 2016
i am using LPCxpresso8.1.4 version on Windows 7 64 bit platform
1,333件の閲覧回数
lpcware
Content originally posted in LPCWare by vtw.433e on Thu May 19 01:37:44 MST 2016
Which version of LPCOpen did you download? Was it the version for LPCXpresso? And how did you import?
1,333件の閲覧回数
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Thu May 19 00:03:12 MST 2016
More information is needed to help you. First what LPCXpresso IDE version did you install, and for what host operating system?
Thanks and regards,
LPCXpresso Support
