LPCXpresso v5.0.12 released
574 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Fri Nov 23 05:15:49 MST 2012
LPCXpresso v5.0.12 has been released. Changes in this release include:
[LIST]
[*] To improve debug startup time, the debug configuration now prompts  to select a debug emulator and stores it. Future debug sessions using  that configuration will use the stored emulator.
[*] Added support new parts/families from NXP
[LIST]
[*] LPC11xxLV
[*] LPC8xx
[*] LPC11E3x
[/LIST]
[*] Fixed resource leaks when terminating a debug session
[*] Added missing TDI/TDO flags in Jtag configuration dialog
[*] Added preference to control whether Redlink is booted
[*] Major performance improvements to LPC18/43 SPIFI flash drivers
[*] Fix indexer configuration
[*] Fix problem with display of Semihosting output on Linux
[/LIST]
1 回复
567 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Tue Nov 27 08:51:02 MST 2012
We now have an FAQ which explains in more details how the new debug emulator selection functionality works. You can find this at:
http://support.code-red-tech.com/CodeRedWiki/DebugEmulatorSelectionDialog
CodeRedSupport
