LPCXpresso import incompatible with WIN 7 64Bit?
1,237 次查看
lpcware
Content originally posted in LPCWare by StephenHawkings on Fri Oct 28 04:47:32 MST 2011
Dear Collegues,
since a few days I own a new computer with Windows 7 64Bit Professional edition. I installed LPCXpresso 4.1.0 and now face the problem, that I can not import anything at all. Independent of, to import just a single file, or a complete project, I get as a result unwanted, super-long pathes. The path copies itself again and again into the path. Now I have this:
"C:\Test\_NXP_LPC1100_Examples_V2.0\_NXP_LPC1100_Examples_V2.0\_NXP_LPC1100_Examples_V2.0\_NXP_LPC1100_Examples_V2.0\_NXP_LPC1100_Examples_V2.0..........."
And of course, it's not possible to delete it. Only with Linux-CDROM or other foreign tools I can delete this path.
Does anybody have a clue, how to solve this trouble?
Best regards!
StephenHawkings.
4 回复数
1,218 次查看
lpcware
Content originally posted in LPCWare by StephenHawkings on Sat Oct 29 01:20:32 MST 2011
Today I tried again, and I was able to import 4 different projects without any trouble. The "trouble-maker" project, too. Also, I imported different single files to different projects and workspaces. All works fine. I started all my other software which I'm using usually, and still I can not reproduce the super-long pathes. Three days ago, my collegue from IT department needed to use a Linux-CDROM to catch and delete the super-long path. Today all works fine. Computer-world is really strange sometimes. Hopefully, my issue is solved.
Best regards!
StephenHawkings.
1,219 次查看
lpcware
Content originally posted in LPCWare by CodeRedSupport on Fri Oct 28 15:44:51 MST 2011
We use Win64 for development and have not seen this problem. Can you tell us *exactly* how to reproduce? Please include the installation location for your product and the full path to your workspace. We need to try and reproduce your exact scenario.
1,218 次查看
lpcware
Content originally posted in LPCWare by StephenHawkings on Fri Oct 28 11:35:50 MST 2011
Just tried to import a single file; whole project; both result in a super-long path. Seems to me "Import" has a problem. I use Win 7 Prof. SP1.
SH
1,218 次查看
lpcware
Content originally posted in LPCWare by TheFallGuy on Fri Oct 28 08:24:51 MST 2011
Can you explain what it is you are doing? I have been using LPCXpresso on Win64 for over a year and never had any such problem.
