LPCXpresso IDE with openocd
lpcware
Content originally posted in LPCWare by Cosik on Sun Nov 25 16:03:03 MST 2012
I integrated my ide with openocd and versaloon on linux, and I can't see Peripherals+. Is it normaly?
lpcware
Content originally posted in LPCWare by Brutte on Tue Nov 27 12:31:17 MST 2012
Quote: Brutte
Use EmbSysRegView.
under Eclipse + CDT.
lpcware
Content originally posted in LPCWare by Cosik on Tue Nov 27 00:10:08 MST 2012
I try to debug LPC1768 using Amnotec JtagKey under LPCXpresso IDE.
lpcware
Content originally posted in LPCWare by Brutte on Mon Nov 26 07:14:48 MST 2012
The question is why did you do that?
Do you want to debug non-LPC chips under LPCXpresso IDE or do you want to use non-CR dongle with it?
